is it safe to...
Old Aug 13, 2004 | 09:55 AM
jimmyfly's Avatar
jimmyfly
Default is it safe to...
use a 350w - 1350w amp kit on a 300w amp?
Old Aug 13, 2004 | 11:16 AM
TTT's Avatar
TTT
Usually completely safe, unless the power ratings are measured differently. Go to www.bcae1.com/wire and check out what size wire you need for your application, and go from there. When you are wiring your system, really the only wire that changes with amplifier power is the power/ground wires. Make sure they are sufficient size and fuse properly and you will be set.
Old Aug 15, 2004 | 07:03 PM
miguel6632's Avatar
miguel6632
proud 96 sol owner
your safe
Old Aug 16, 2004 | 09:12 AM
SOHKeg's Avatar
SOHKeg
yeah it's fine, that way you got the room to upgrade in the future
