where to find the check engine light plug?
Old Aug 11, 2004 | 10:29 AM
R34Lude's Avatar
R34Lude
96teg
Default where to find the check engine light plug?
I recenlty bought a new integra and the check engine light does not come on. Does anyone know where to find the check engine plug? I was wondering if the plug is loose or the dealer must have unplugged it. Also how to change the light bulb just in case its the light bulb is dead.
Old Aug 11, 2004 | 11:33 AM
ISP James's Avatar
ISP James
DAMIMRED
check and see if there is a bulb at all, first...
if this is a 94+ integra, there are 2 screws over the guage cluster... undo them, pull the bezel out and then there are 3 more screws holding the cluster in. one at the top, one on the left and one on the right. you will see them. now the cluster pulls out and there should be 3 wiring harnesses plugging into it. unplug them and take the cluster completely out, if there is a hole behind the CEL slot, then the bulb is removed.
if that dealer did in fact tamper with the CEL, he could lose his license, and IMO, he should lose it... so dont be afraid to report it to the state and have them investigate.
Old Aug 11, 2004 | 12:13 PM
R34Lude's Avatar
R34Lude
96teg
I'm a noobe so where should i report it to then? If i tamper with the thing then there wouuld be no evidence left for the state to find. So i am confused ?? How to deal with this issuse
Old Aug 11, 2004 | 01:46 PM
ISP James's Avatar
ISP James
DAMIMRED
you go to the DMV and report it there, use the state dealer #
its not tampering with it, you checked to see if the bulb was there and it wasnt...
Old Aug 12, 2004 | 10:35 AM
R34Lude's Avatar
R34Lude
96teg
I just checked it yesterday and the light bulb was there but it wasn't tighten. It was very loose so that it would not turn the light on. Now that it is on the engine light is on. I kinda figure that the engine light was suppose to be on when i failed the emission test using obd2 and was told that there was suppose to be a check engine light. I have to ask another question what can cause alot of build up in the gas cap area. It build too much pressure and the it tosses an engine light and won't let me pass emissions.
Old Aug 12, 2004 | 03:58 PM
ISP James's Avatar
ISP James
DAMIMRED
too much pressure in the gas cap area should have nothing to do with emissions...
Old Aug 14, 2004 | 08:03 PM
joewhite's Avatar
joewhite
are you going to report it?
Old Aug 16, 2004 | 04:13 AM
JimBlake's Avatar
JimBlake
On OBD-2 cars there's a pressure sensor in the gas tank. The ECU uses that to see whether the tank's airtight like it should be. Evaporation from the tank counts as unburned hydrocarbon emmissions.
It'd be good to know the error code, but a wild guess would be either...
P1456 (90) EVAP leak - fuel tank system
P1457 (90) EVAP leak - control canister system
Old Nov 6, 2006 | 07:29 PM
gulfview's Avatar
gulfview
Too much pressure in the gas cap area could indicate a malfunctioning EVAP system.
Old Nov 6, 2006 | 07:40 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Not to bust balls... but this thread is over 2 years old.
Let dead threads lie undisturbed.
