Will this just bolt on?
Old Aug 9, 2004 | 07:38 AM
addifan's Avatar
addifan
Default Will this just bolt on?
http://www.city-speed.com/webstore/s..._typerbar.html
I am thinking about ordering this for me 2001 LS. Will it bolt directly on, or will I have to make some modifications to get it to fit?
Old Aug 9, 2004 | 07:58 AM
blk92integ's Avatar
blk92integ
yes it does....if its made for the car then all you have to do is unscrew a few bolts, place the strut bar and screw the bolts on again
Old Aug 9, 2004 | 08:09 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
That thing's a piece and is just for looks. I wouldn't reccomend getting it if you're looking for any performance whatsoever...
Old Aug 9, 2004 | 08:22 AM
addifan's Avatar
addifan
Which one would you recommend?
ISP James's Avatar
ISP James
DAMIMRED
just get an OEM gs-r bar...
Old Aug 9, 2004 | 09:29 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
For what you're getting, I wouldn't spend the extra money just for JDM bling.
Check your local auto recyclers... A GS-R bar will work just as well for less money.
Old Aug 9, 2004 | 04:46 PM
Epoch's Avatar
Epoch
I have a GS-R tie bar FS. PM me with a price offer if you want it
Old Aug 9, 2004 | 10:03 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you want turning performance, go with an ITR rear sway bar. A bit more expensive but definitely worth it. The front strut bars don't really do anything. Spend your money on something more useful.
Old Aug 10, 2004 | 06:25 AM
ISP James's Avatar
ISP James
DAMIMRED
not true
front strut bars reduce understeer. heavier rear sway bars create oversteer. eitherway, you neutralize understeer but id go with the strut bar, its cheaper, easier to install... ITR bar will tear your subframe if you dont get a reenforcement kit... if the strut bar isnt enough, start looking into heavier sway bars.
Old Aug 10, 2004 | 09:19 AM
ZiGeNX77's Avatar
ZiGeNX77
What is this reinforcement kit you're talking about? And how much does it cost?
