Oil Leak
Old Aug 3, 2004 | 08:51 AM
kmannick's Avatar
kmannick
Default Oil Leak
I am using a JDM B18C block with CTR pistons and USDM B18C Head. When I start the car, oil is leaking out from between the head and block under the distributor. I have changed head gaskets and even oil sensors. I am totally out of ideas.. Any help is appreciated..
Old Aug 3, 2004 | 09:50 AM
timmy8151's Avatar
timmy8151
Sounds like your cam seal. You can get an OEM one or an aftermarket billet one. The OEM one is plastic and about $5. Aftermarket metal seals range from $20-$25.
Old Aug 3, 2004 | 10:05 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Cam seals..without a doubt.
Old Aug 3, 2004 | 10:46 AM
kmannick's Avatar
kmannick
would that make the oil come from the area of the head gasket? cause it is not coming from by the cams. It is coming from between the block and the head
