Adjusting Clutch
Old Jul 30, 2004 | 06:04 AM
HoNdAeVo's Avatar
HoNdAeVo
I railed YOUR sister.
Default Adjusting Clutch
I have a 95 Integra LS... How do I adjust my clutch pedal so the engagement of the clutch is closer to the floor?
Old Jul 30, 2004 | 06:21 AM
slickboy's Avatar
slickboy
ECHC junkee
Unfortunately, hydraulic clutches are not adjustable as the older cable clutches were.
Old Jul 30, 2004 | 06:24 AM
HoNdAeVo's Avatar
HoNdAeVo
Then how do i make the clutch pedal engage closer to the ground?
Old Jul 30, 2004 | 07:32 AM
LT's Avatar
LT
The deer had to die!
Old Jul 30, 2004 | 07:33 AM
LT's Avatar
LT
if you want to adjust the pedal. however, because the system is hydrolic, it's basically self-adjusting.
Old Aug 2, 2004 | 06:33 AM
JimBlake's Avatar
JimBlake
It'll self-adjust itself until the slave cylinder runs out of travel. If the engagement point starts happenning higher & higher, then your clutch is worn thin.
If the pedal is adjusted wrong, OK. But don't use that adjustment if you're in denial about a worn-out clutch...
Old Aug 2, 2004 | 06:38 AM
ISP James's Avatar
ISP James
DAMIMRED
my question for you is .... why?
most people want a quicker engagement, wouldnt you want it to engage further from the floor so that you dont spend as much time with pedal travel?
one of the things i like most about my integra over other sport compacts i have driven is the fact that i dont have to press the pedal allllllll the way to the floor to get clutch engagement....
