Ignition Timing
Old Jul 6, 2004 | 11:52 PM
idol4232003's Avatar
idol4232003
Default Ignition Timing
my chilton's manual says to use part# 07PAZ-0010100 on the service check connector when checking the ignition timing. do i really need this? my accord only needs to short 2 pins...so i'm assuming this part just does the same thing.
Old Jul 7, 2004 | 06:38 AM
LT's Avatar
LT
The deer had to die!
use a (plain, metal) paper clip
Old Jul 7, 2004 | 10:11 AM
idol4232003
thanx...that's what i thought. btw, the service check connector port is that one with the black and brown/white wires under the glove box, right? i have a 97 teg GS.
Old Jul 7, 2004 | 12:05 PM
LT's Avatar
LT
you are correct
Old Jul 7, 2004 | 12:22 PM
idol4232003
hmmm...now that i'm thinking about it....what does shorting those 2 wires actually do?
Old Jul 7, 2004 | 12:51 PM
LT's Avatar
LT
it trips the ECU into diagnostic mode.
Old Jul 15, 2004 | 12:21 PM
idol4232003
hmmm....why does the ECU need to be in diagnostic mode when adjusting the timing?
Old Jul 15, 2004 | 12:51 PM
JimBlake's Avatar
JimBlake
You're setting 'base' ignition timing. You don't want the ECU to be making little adjustments of it's own. Diagnostic mode tells the ECU to leave it alone.
Old Jul 15, 2004 | 03:19 PM
LT's Avatar
LT
^what he said.
Old Jul 15, 2004 | 11:32 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Yeah... it automatically retards the timing at idle, and if you're watching it with a strobe, you can see it fluctuate around 14 BTDC even if your stock timing is set correctly at 16 BTDC.
FYI, I have my GS-R set at 19° timing, and it works great with 91 octane on even really REALLY hot days.
