Koni Yellows or Koni Yellow SP3's
I can get the SP3's shipped to my door for $540.00 or the regular ones shipped for $520.00 so my silly question is would you pay the difference for the SP3's a friend of mine has the regular ones and his drop looks nice but will the SP3 sit lower if everything is set at the same level thanks
I have the SP3s.. they're better suited for a more aggressive setup. a search would have netted you this info, btw... but as mrfatbooty said in another thread..
except that i think the regular yellows have 2 spring perch settings on the rear, not 3 (if i remember correctly).
in other words, yellow SP3 > yellow.
They're like Koni Sports but they are shortened to help gain back suspension travel when lowered, they have valving designed to deal with lowering, and their spring perches have a 5-position height adjustment instead of the normal 3.
Originally Posted by WiLL
what springs are you going to be using with those shocks. heck, its only $5 more per stock for the SP3...
