Adding sub and amp with stock head unit?
Old Aug 8, 2002 | 03:48 PM
Import-Tooner's Avatar
Import-Tooner
skoooooie!
Default Adding sub and amp with stock head unit?
Has anyone added a sub to their type-s and still used the stock Bose head unit? I took it in today to have it done and something isn't working right. I need to know who has done it before so we can give them a call and ask a few Q's.
+Chanc+ says: I went pee with gloves on.
SKOOIE!!!
Old Aug 9, 2002 | 04:24 PM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
I thought you just had to take the wires from the sub in the spare tire and either hook them into high level inputs on your amp or get line output converters.
do a search on www.clubrsx.com , there are tons of threads about this there.
Old Aug 9, 2002 | 08:13 PM
94civicEX's Avatar
94civicEX
I got worms.
Well...from what I understand, you can't really replace the deck anyways, and why would you want to bro'? it has a in-dash 6 cd disc changer .
99 Integra GSR
06 TSX
duck squad member #00003
Old Aug 10, 2002 | 10:16 AM
RsxS's Avatar
RsxS
Yes definatly the 6-disc but if you have to change then all you do is get the radio bracket off a base model. it will fit right in.
Old Aug 16, 2002 | 06:51 AM
b_ridin's Avatar
b_ridin
why can't you replace the deck?
Old Aug 17, 2002 | 09:39 PM
silvagsr's Avatar
silvagsr
Alrighty i got this shiznit.... you go to your local sound store and purchase a wire to rca converter... you take you lines running to the left and right speaker and you run them to the converter...then the rca's will plug into your amp....that will give you your sound then you run the amp wire to your battery and the relay to your fuse box under the dash somewheres(sorry own a teg) , then you run your amp power line(red) to your battery with a fuse about 6 inches in-line from the battery.... WAMO you have a perfect stock look (unstock sound)..
OH yeah dont forget to ground the amp really good....
Old Aug 27, 2002 | 09:01 PM
NSBTypeS's Avatar
NSBTypeS
MMM MMM Bitch
It's really easyif you know what you're doin, otherwise Circuit City or any other installers could do it. I have had my subs and amp in for about 3 months. They work great except it doesn't hit as hard on the radio.
Old Aug 29, 2002 | 11:59 AM
jgrotkier's Avatar
jgrotkier
AIM SN: Johann14420
don't use the rear speakers to hook up the amp, I believe they filter out the lows on the speakers, if you hook a sub up to them, you'll never be getting all the bass that you should.
Thats why you hook it up to the wires from the stock sub.
Old Dec 6, 2005 | 09:17 PM
trdle86's Avatar
trdle86
Default cau somebody help me w/ my radio
i got the pioneer navi. and i wan to keep my bose woofer. but i dont know how to run the wire , can use the rca convertsion
Old Dec 7, 2005 | 03:45 PM
d0csh03lace's Avatar
d0csh03lace
trdle, if u have an amp, maybe you can run the sub the amp
and the whole set up from the rear speakers, ISNT as good as the set up of pulling everything out and running wires, but its EASIER
DeadLock23
3
Aug 14, 2002 09:23 AM
focker74
92+ Civic/EL & Del Sol
12
Aug 9, 2002 06:22 AM
