H22A injectors.........need help
I know there are saturated for the 92-95 motors and peak/hold for the 96 and up. Do the H23 motors use the same injectors and if so will the ones from a 94 work on a 99 motor for my swap? Thanks.
i believe h23 used the same injectors as the f22. all obd1 f and h series injectors are low impedence saturated.
i am assuming you are puttin a 99 h22 in a obd1 accord.. you should use obd1 h22 injectors, h23 injectors are not big enough. you can use the 99 injectors if you remove the resistor pack.
What exactly has to be done to remove the resistor pack? If you could explain I would appreciate it greatly. Also, will doing this work as good as having obd1 injectors or would it run better with the obd1's? I am learning as I go so this info helps tremendously.
Thanks
Thanks
if you have obd1 injectors you NEED the resistor pack so if you have those dont worry about it.
if you have obd2 injectors you must remove the resistor pack.
to do this all you do is connect all the wires together that were going into the resistor pack. there should be 5 wires going into the pack... 1 for power, 4 going to the injectors. tie all 5 together.
almost....... i always say its better to use the injectors that the ecu was designed to run.... i know quite a few people running with obd2 injectors with the resistor removed with no problems. but if you can get your hands on some obd1 injectors thats what i would do..... if not then removing the resistor will be fine. make sure to leave enough wire on the connector so you can put it back incase one day you decide to get obd1 injectors
Toy Civic
9
Feb 20, 2007 11:42 AM
snacks
5
Feb 25, 2004 02:48 PM
xtreme
Jan 16, 2004 07:14 PM
accordh22a5
May 16, 2003 06:35 PM
