FS/FT: S4 RX7 TII for Integra Type-R
I am looking to trade or sell my RX7 for an Integra Type-R, I am pretty much open to all types (stock to modded) But must have no rust, clean/clear title, and no bent frame.
Here is info on my car:
1987 TII Black over Grey
w/73k on the chassis
Clean and clear PA title
Has power windows and steering, rear wiper, moonroof (works sparodically needs tracks cleaned), AC and ABS pumps both removed.
NEW Reman with 1,200 miles with All new gaskets, o-rings, grommets, Vac lines, etc.
NEW MOP lines, Upper and lower radiator hoses, TPS, motor mounts, coolant level and thermo sensor, fuel filter
Racing Beat
Oil Baffle plate (no oil leaks)
3" Turbo back
Toe Eliminators
CorkSport SS Clutch line
HKS FCD
Injectors sent to RC for balancing and cleaning
NEW Front rotors, calipers, and pads
MazdaTrix ABS removal kit
NEW Camber links
H4 Headlight conversion
Exedy Street/Strip Clutch
GoodRidge Stainless steel brake lines
Heavily ported Wastgate with a larger flapper
Calipers sprayed Red
Polished interior/exterior of UIM and LIM
AC pump and ABS removed (still have both)
Resprayed the entire underbody, fender wells, engine bay from frame rails down, front and rear subframes, halfshafts, diff, and all other rear suspension parts with a rubber based undercoating
All the above for $5900 OBO
Here is a list of extra parts that I will include at an added cost, so basically you can chose what you would like to add and I will either include or install it for you if you would like. Mist parts were not installed and are new, if they are used they have the same amount of miles as te engine (1200)
ELECTRONICS:
Apexi SAFC 2 (black version)
Blitz SBC Spec R
Innovate! LM-1 w/RPM convertor (wired for rpm, boost, intake air temp, water temp)
ENGINE:
Blitz DD BOV
Magencor 10mm
HKS Intake
FD Alternator with twin pulley
FD Fuel Pump
Hose Techniques Silicon Vac
Koyo Radiator
FEED Radiator Caps
EXHAUST:
Racing Beat 2.5" Stainless Steel DP/MP and FEED Sonic HSR
Magnaflow Stainless Steel Cat welded w/flanges
SUSPENSION:
Mazdatrix Camber Adjuster (non removal type)
FEED Strut tower bar
Silk Road Spec RM/A8 8/6kg w/ extra set of springs 10/8kg
Super Now! Tie Rod ends w/spacer
DRIVETRAIN:
BBS Vert wheels
EXTERIOR:
RE Amemiya Whaletail spoiler (painted and mounted)
JDM Mirrors (painted and mounted)
OEM Mudflaps
S5 Tail lights
INTERIOR:
Pioneer DEHP3600
Infinity 4" and 6.5" speakers
S5 Radio Surround and Air vents
MazdaSpeed Shift Knob
Everything listed installed for $12,800 OBO
So throw me a trade or a reasonable offer email me at sikokillr@aol.com
Racing Beat
3" Turbo back
Toe Eliminators
HKS FCD
NEW Camber links
ELECTRONICS:
Blitz SBC Spec R
ENGINE:
Blitz DD BOV
Magencor 10mm
HKS Intake
FD Fuel Pump
Koyo Radiator
FEED Radiator Caps
EXHAUST:
SUSPENSION:
DRIVETRAIN:
BBS Vert wheels
EXTERIOR:
OEM Mudflaps
S5 Tail lights
INTERIOR:
Pioneer DEHP3600
ITRinEJ1
Jul 10, 2004 11:58 AM
b18c1delsol94
Vehicle Classifieds
Mar 26, 2004 06:06 AM
