is water supposed to be here b18b1
was replacing head gasket and seen this is water supposed to be here around the piston cylinder there was water on a few pistons as well and do i need to remove this water thanks in advance
Don't remove the coolant around the cylinder bores. The cylinder bores are free-standing on B-series; also known as "open deck." The head gasket and the head provides the seal between the bores and the block.
It would be wise to siphon the coolant off the pistons, however.
Related question... is the engine consuming coolant?
