Adding amp to factory head unit???
Does any know if there are RCA outputs on the factory system in a '98 Civic EX 2-door? I just purchased an Alpine amp that has the speaker level in, but I'd rather feed it a line level input and not use an adapter. I'd like to keep the clean look of the stock head unit if I can.
I seriously doubt there is, but I thought I'd ask before I pull my dash apart. If it doesn't, I guess I'll just use the amps speaker inputs.
Any ideas???
- awb :rockon:
Any ideas???
- awb :rockon:
There is something you can use without RCA outputs but I can't remember what it is called. I had it in my car 4 years ago before I had a head unit. It has two wires that connect to your rear speakers and RCA's coming out the other end to plug into your amp. Its the ghetto way of hooking up an amp if you don't have RCA outputs. Go to a stereo shop and ask them, they should have one for sale.
Thanks guys....yeah, I'm hip to the converter. Agree with the "ghetto" install. Since the amp has one built in, I'll try that first. If no go, then I'll buy the converter.
Appreciate all your help...
