Slipping sound during acceleration
Old Apr 26, 2004 | 09:58 PM
maldini's Avatar
maldini
Default Slipping sound during acceleration
I got some slipping sound during acceleration. It comes from the left front side mostly. Normally, it happens when the car has been running for a while.
When I let go the gas it goes away. What could be the problem? I am now suspecting a loose engine mount.
Old Apr 27, 2004 | 01:58 PM
Kai's Avatar
Kai
Rotorphile.
Like, when you nail it from a standstill, or around a corner? That could be your lack of an LSD.
Old Apr 27, 2004 | 02:19 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Slipping sound? :eh: Like metal on metal?
I've heard of clunking, banging, clapping, clacking, thumping, rumbling, rubbery and stiff...but slipping? :chuckles:
Color me confused. h:
Old Apr 27, 2004 | 03:39 PM
maldini's Avatar
maldini
Not necessarily from a standstill or around a corner. Can be anytime during accleartion. Just normal accleration, and I am not even accelerating hard.
Old Apr 27, 2004 | 03:41 PM
maldini's Avatar
maldini
Maybe more like clunking, or rumbling, certainly not rubbery since I don't think the tires are touching anything.
It is really like some metal parts slipping against each other.
Old Apr 27, 2004 | 07:31 PM
XSrcing's Avatar
XSrcing
check your front brakes. they may be starting to wear out.
Old Apr 27, 2004 | 08:52 PM
dc2integra's Avatar
dc2integra
Default sound?
it could be your tranmission is slipping in certain gear, does it like like a long reving sound? slips for 2 seconds?
Old Apr 27, 2004 | 10:13 PM
maldini's Avatar
maldini
I replaced brake pads already. The "slipping" sounds came during acceleraton, not braking anyway.
Old Apr 29, 2004 | 02:15 PM
XSrcing's Avatar
XSrcing
i've heard brakes that only made noises under acceleration, plenty of times.
and you generally cannot hear an automatic transmission slip. give me a little time to think about this.
Old Apr 30, 2004 | 07:08 PM
maldini's Avatar
maldini
I am thinking of two clues:
1) It is accleration-related. Since when I let go the gas it goes away.
What parts are engaged when I step on gas pedal and then disengaged
when gas pedal released?
-drive shafts?
-gears (the car is automatic)?
-CV boots were replaced not too long ago, at that time, the CV joints
were okay. CV boots still fine, not leaking oil
-brake pads, rotors replaced
-engine mount?
-cylinder/ spark plug not firing?
2) It has to do with heat.
Normally, it happens when the car has been running for a while. After I let
the car sit for a few hours or overnight, the problem went away
-the problematic part expands and "slips" against another part
-it sounds and feels like cog wheels sliding against each other abnormally
