my friend cut my bumpstops
Old Apr 21, 2004 | 07:07 AM
ISP James's Avatar
ISP James
DAMIMRED
Default my friend cut my bumpstops
when my friend helped me install my H&R sports with KYB AGX's, he cut the bumpstops in half... today, when i was reading my info from H&R, they said specificly do not cut the bumpstops.... am i looking for trouble if i dont replace them?
Old Apr 21, 2004 | 08:48 AM
shivers's Avatar
shivers
Moderator Alumni
Hmm ... that seems strange to not cut the bumpstops. Every suspension I've done, I've cut the bumpstops. I'd say you should be fine and don't need to replace them.
2005 s2000
Old Apr 21, 2004 | 10:02 AM
ISP James's Avatar
ISP James
DAMIMRED
yeah he told me he always cuts em... i didnt think anything of it, experience usually over rides instinct.... just got a little nervous when i saw the directions.... didnt put the dust guards on either and that still has me a little nervous
Old Apr 21, 2004 | 10:33 AM
reno96teg's Avatar
dust covers should be on.
Old Apr 21, 2004 | 10:56 AM
shivers's Avatar
shivers
Moderator Alumni
I agree.
2005 s2000
Old Apr 21, 2004 | 11:28 AM
osaficles's Avatar
osaficles
what would cutting the bump stops do? reduce bouncing? i am curious cuz i have no idea.
Old Apr 21, 2004 | 11:49 AM
Padawan's Avatar
Padawan
Future Jedi
The bump stops are intended to provide a degree of "cushioning" once the suspension reaches the end of its travel and bottoms-out. In other words, if you were to totally remove the springs from the car, it would be resting on the bump stops. The idea of cutting the stops when installing a lowered suspension is to increase the amount of travel before hitting the stops (in order to try to compensate for the lost travel resulting from lower height).
Some bump stops are actually designed as a sort of " additional spring" (rather than a simple "stop) providing a added form of progressiveness to the spring rates in the last portion of the travel.
Old Apr 21, 2004 | 04:33 PM
ISP James's Avatar
ISP James
DAMIMRED
hmmm... should i put the dust covers back on? i know it will be a bitch but i dont wanna kill my struts...
Old Apr 21, 2004 | 04:45 PM
Brad's Avatar
Brad
wooo nascar!
eibach springs instruct you to cut the bumpstops. my H&Rs said not to. so i didnt. :dunno:
Old Apr 21, 2004 | 04:53 PM
b00gers's Avatar
b00gers
yes. they are there for a good reason.
and i wouldnt worry about your bumpstop problem too much.
