weird clusters
Old Apr 20, 2004 | 08:48 PM
ragerized's Avatar
ragerized
dc4 ownerages
Default weird clusters
so i got a new cluster from a 99 LS, however, the gas guage just drops all the way to the left. are the clusters different for different obd's?
Old Apr 20, 2004 | 08:55 PM
ragerized's Avatar
ragerized
dc4 ownerages
also, how cheap are the light bulbs that you replace in your cluster?
Old Apr 21, 2004 | 12:26 AM
Kai's Avatar
Kai
Rotorphile.
uhh.. sounds like you got screwed over and bought a busted cluster.
Old Apr 21, 2004 | 05:04 AM
LT's Avatar
LT
The deer had to die!
98+ cluster requires switching the gas gauge harness, its reversed.
Old Apr 21, 2004 | 08:01 AM
ragerized's Avatar
ragerized
dc4 ownerages
yeah, the guy i traded with also had the same problem. gas guage harness, you say? switch the wires, or what?
Old Apr 21, 2004 | 01:08 PM
Kai's Avatar
Kai
Rotorphile.
I wonder why they did that. :thinking:
Old Apr 21, 2004 | 01:38 PM
LT's Avatar
LT
actually this is what i pulled up...
you have to remove the gas gauge from the 98+ cluster, and put in your old gas gauge...then it will work.
Old Apr 21, 2004 | 01:46 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Is there something better about the '99 cluster that you want to replace your '95 cluster? They're both out of an LS, right?
Old Apr 21, 2004 | 01:50 PM
So.Cal_INTEGRA's Avatar
So.Cal_INTEGRA
trying to keep your miles low? :rick:
Old Apr 21, 2004 | 01:56 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
If you're going to do something illegal, you can roll back your odometer without replacing the cluster. But...that would be illegal.
If you're all set on replacing the cluster, I highly suggest rolling the miles on it forward to match your current mileage.
http://webpages.charter.net/mrfatbooty/odo.htm
Disclaimer: The link above should only be used to match the mileage of a new odometer to the actual mileage of the car, never to roll back your odometer or commit fraud in any other way. That's illegal and if you do it, that's your own fault. I'm providing the link only for purposes of rolling an odometer forward.
