air condition
mines is DAMN COLD even at 72.. i leave it pointing straight up..
stick ur finger in the vent.. u'll see the coldness!
only problem is, i notice that as soon as u turn the a/c off.. damn it gets hot reallllllll quick in the car.. it cannot retain the cold air.. weird! but hey it has temp control so yaY! i leave it at 72 always..
Definitly feel the same way in my civic, on hot ass days the air was cool, but definitly not cold, later that day (when it got much cooler) i noticed it was damn cold, i wonder what does that?
well lets think about this for a second....if its hot outside and you are cooling the air just as much as you would if it was cold outside, the a/c will be cooler when the air outside is cooler....its common sense.
Air conditioning works by removing heat. Technically speaking there is no thing as cooling, you just remove heat. As the outside ambient rises the condenser coil gets warmer. You want to maintain at least a 35 degree difference between the temp outside and the condenser (outside 35 degrees less than condenser temp). http://www.howstuffworks.com/ac1.htm
