Longer oil filter for 2000 Civic?
Old Aug 4, 2002 | 01:38 AM
Patman's Avatar
Patman
Default Longer oil filter for 2000 Civic?
I was wondering if there is a longer oil filter that I can run in my wife's 2000 Civic? I am currently running the K&N HP1004, although I have also run the Pure ONE PL14459, the Mobil 1 M1-104 and Ultraguard UPF1127s in the past.
Old Aug 4, 2002 | 01:47 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default Re: Longer oil filter for 2000 Civic?
humm... longer oil filter? i think they are the same length as those for previous civics. as for filter... i'd recommend using OEM filters from honda. there was a topic on here last year about filters and there were research done on it and honda was the best one.... correct me if i am wrong, but i remember reading it from somewhere.
Old Aug 4, 2002 | 01:54 AM
DSC's Avatar
DSC
Long way from home
Ah you can get HAMP filters (Honda After Market Product I think) off ebay. Spoon uses them on their race cars. They got small, reg, and large. I believe Spoon uses the small ones. Under extreme temperature, they retain oil pressure.
Old Aug 4, 2002 | 02:00 AM
tokyoracer's Avatar
tokyoracer
got JDM milk???
DSC... if you have the link for it... can you please post? i wouldn't mind checking them out...
Old Aug 4, 2002 | 02:10 AM
DSC's Avatar
DSC
Long way from home
Ah there was a pretty big post on honda-tech about them. I guess they cleaned some stuff out. Cant find it.
However, the small HAMP filters are only good if you run your car hard.
Old Aug 4, 2002 | 02:43 AM
Patman's Avatar
Patman
The OEM Honda filters here in Canada (I'm in Mississauga Ontario) are Fram, so I won't be using those! I'm probably going to go with the Purolators, since they are a lot cheaper than the K&Ns I'm using now, and I've recently learned that the K&N oil filter isn't that efficient, it's geared more for high flow, and really only stops about 50% of the particles at 20microns and lower. The Purolators (even the standard ones) are rated at 99% efficiency for 10-20 micron particles. The PureONEs are even better than this.
Old Aug 4, 2002 | 04:49 AM
Gen4dr's Avatar
Gen4dr
i suggest buying blue Honda OEM filters off the net if you cant get them at your dealer.
i had no idea, ive seen them on ebay but i thought they were generic because everything on ebay got Spoon and JDM written all over it:dunno:
Old Aug 4, 2002 | 09:33 AM
Patman's Avatar
Patman
An Amsoil dealer told me today that the SDF-36 filter is about a 1/3rd longer and will fit. So now I just need to find what Purolator filter that cross references to and I'm good to go!
Old Aug 6, 2002 | 08:34 AM
4-banging's Avatar
4-banging
Whats wrong with FRAM? I've been using them for years.
Old Aug 6, 2002 | 08:47 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
MANY MANY race cars use them
