boosted Type R
Old Jan 14, 2004 | 09:48 AM
im_new's Avatar
im_new
Hey everyone, I'm new to this forum but have been searching around it for the last week or two and I've come up with some questions. I found a turbo kit called TSI Extreme, it has a Garrett T25. This kit seems pretty well put together and it runs at 6 psi. I'm not looking for an all out 450whp Type R, i just want something that'll be quick on the street since there are no tracks in my state. I have $5k to work with but I have a job so additional costs wont be a problem. The kit is $2700. I plan on running 6-7 psi for now because the internals will remain stock for a couple months after installation of the turbo. I'll also be getting 450cc injectors, Walbro fuel pump (255lph, maybe?), 3" custom catback, and the ACT clutch/flywheel package, along with Hondata for tuning. Is this a safe way to start off boosting my Type R until i get the bottom end built? Keep in mind, i'll be running 6-7 psi. Thanks for your help. This is my third Honda, but my first boosted one! ops:
Old Jan 14, 2004 | 12:49 PM
Jan Niemi's Avatar
Jan Niemi
The T25 is way, way too small for a Type-R motor...not enough flow potential. You need a T3 at the minimum, but preferably a T3/T4 hybrid.
The T25 will spool super quickly but will fall on its face in the upper end.
Old Jan 14, 2004 | 08:43 PM
ITR41's Avatar
ITR41
yeah at the least get a greddy kit and fit to your car. I have that set up and it runs well with good spool. T3/T4 is another good set up. T25 is way way too small.
Old Jan 15, 2004 | 06:47 AM
im_new's Avatar
im_new
Thanks for your opinions on the setup guys. Yeh, all of the kits I see for the R are T3/T4's so maybe I should go with the Revhard kit. So in place of the TSI kit, does everything else sound right for starting off? Anything significant i'm missing? Thanks for the info.
Old Jan 15, 2004 | 08:28 AM
ITR41's Avatar
ITR41
well I would say honestly if you are using hondata just buy bigger injectors now. I would go no smaller than 660cc and avoid RC injectors....go with precision they are cheaper and have a better spray pattern. also for safety I would honestly use the inline pro head gasket and block gaurd....jan and erik run stock head gaskets so it can be done, but I can run up to 22psi on that gasket on a good tune on stock internals. cars have gone as fast as 11.2 on it....also look into a block gaurd if you are doin the gasket
Old Jan 15, 2004 | 01:43 PM
im_new's Avatar
im_new
Thank you for your reply. I think I should definately be boosting the Type R, sounds like a good idea. No one in my town even has a Type R let alone a BOOSTED one. :twisted:
