Check Engine Light "on"
Old Nov 28, 2003 | 09:13 PM
5-Lug's Avatar
5-Lug
Hey guys, probably about last Wednesday my check engine light came on in my 98 ITR. Sunday afternoon my buddy with a code checker ran the code of "P1457". Well, he cleared the code and said to see how it goes, it'll probably come back on when you jump on it... I jumped on it a few times that day and the next day and nothing, then finally Tuesday night while I was driving normal the light came on again, I'm assuming for the same thing. When I look up P1457 it gives something about a "Leak deteced in EVAP control system". Can anybody specify what this is, and is it a problem that needs to be looked in to? And just for curiosity, is there a fuse you pull to reset your computer? I thought I read somewhere that if you pull the clock fuse it resets your computer, or did I just dream that? Any help is appreciated. Thanks guys.
Old Nov 29, 2003 | 07:20 AM
Dave-ROR
Guest
Posts: n/a
You pull the radio backup fuse..
is the gas cap on tight? (serious) could also be a bad evap bypass solenoid. If you check the code through the MIL coding, it should come up with a code 90.
Old Nov 29, 2003 | 07:23 AM
Type R 98's Avatar
Type R 98
There's a red reset button under the steering column near de fuses
Old Nov 29, 2003 | 09:27 AM
Dave-ROR
Guest
Posts: n/a
For the ECU? Never that I've heard of. There is a reset box (with a blue/white button on my car) for the Maint. Req. light, which is NOT the check engine light.
Old Nov 29, 2003 | 10:50 AM
98cwitr's Avatar
98cwitr
Where's the DC5R???
just take off the positive battery terminal for a few minutes...that'll reset the ECU
Old Nov 29, 2003 | 11:42 AM
5-Lug's Avatar
5-Lug
Thanks for the replies guys. I tried the gas cap because the previous owner said he had to replace the gas cap before because of that reason, and about 2 weeks after I got the car, the check engine light came on and it was the gas cap, but this time it wasn't. I know about the button for the Maintenance Required but it didn't work for the check engine light =(. I'll try the back up radio fuse to reset, if not then I'll just have to pull the positive battery. I know that'll reset it but I just didn't feel like setting my CD Player back to the way it is now with the frequency and such. Plus when I got my alarm put in the other week my clock was reset but my CD Player settings were the same and that's when I swore I read something about pulling the clock fuse to reset the ECU because I remember thinking that's what they must have done. Anyway, thanks for the help guys, I'll see how it goes.
Old Nov 29, 2003 | 03:58 PM
Trey
Guest
Posts: n/a
1) Back up fuse will work
2) Pull the NEGATIVE Terminal
3) Square button under the dash only works for Maintenance Light
Considered that it might be a bad O2 sensor?
