Running on 3 cylinders
Old Nov 18, 2014 | 07:20 AM
Gsrtyperteg's Avatar
Gsrtyperteg
Default Running on 3 cylinders
Ok so I have a problem with my 97 gsr teg. It's running on 3 cyls. Here is what I have done to get where I am and need help. I have pulled #1 #2 #3 #4 plug wires all have spark so I proceed to check again and #4 has spark as well so I checked injectors same 123 are spraying but num 4 isn't i tried switching injectors around and problem stays at num 4 not spraying. I have pulled engine harness and checked all wires no shorts. I changed my hondata ecu to 3 different others and same problem any help figuring this out would be appreciated
Old Nov 18, 2014 | 07:24 AM
Gsrtyperteg
I did pull fuel rail and zip tied injectors to it cranked to see if spraying and 123 sprayed 4 not spraying so I switched all injectors around again and same problem stays at number 4
Old Nov 20, 2014 | 06:01 PM
ChrisS's Avatar
ChrisS
What are the check engine light codes?
(if it's throwing any)
Compression test results?
Leakdown test results?
Does your car have a fuel injector resistor pack?
(if so, check the Ohm measurements for each injector.)
Use electrical contact cleaner on the #4 injector connection.
The ECU might be able to detect whether or not a cylinder is producing power.
No power produced may cause the ECU to cut off fuel to the affected cylinder.
take care,
ChrisS
Old Sep 9, 2015 | 07:33 AM
trm4life's Avatar
trm4life
trm4life
Considering the money you'll spend, just buy new plugs wires cap and rotor. After that its your distributor. Use NGK copper plugs.
