i'm planning on building my car for some major horsepower (500HP), and I have some of these items and plan on getting some others tips would be greatly appreciated as well as advice on possibly what I forgot. But here it goes, currently modified on my ITR. Buddy Club racing spec 3 exhaust, Spoon plug wires, AEM adjustable fuel regulator, RevHard stage 2 turbocharger (T3To4B)kit (which includes wastegate, Vortech FMU, Vortech blowoff valve) and Mugen ECU chip. I have Jun cams, Eagle Rods, JE 9:0:1 compression pistons waiting to be installed. I plan on getting 720cc injectors, swapping my Mugen ECU chip for Hondata ECU, thicker gasket, Darton sleeves, Total seal rings, Clutchmasters clutch, Ferria valves, MSD digital 6. That's all I can think of right now. Any suggestions, tips, advice?
you need cams that aren't all motor cams.....you will also need a bigger turbo to make 500whp....go precision or a t3/60-1 set up......and you will need bigger injectors.... go for 1000cc or so
what type of cams are there for turbo applications? and also I wanted new camshafts for my turbo app. but I was told the overlap would be to big. :twisted:
hondata is the way to go....powerFC is nice but hondata has so many more tuners and is easier to tune once you learn your way around it. I would go golden eagle on the block cause they use iron sleeves but retain the water jacket to help with cooling.
