Resetting ECU without pulling battery terminal...which fuse????
Old Aug 16, 2003 | 02:38 PM
typeruz's Avatar
typeruz
also, is this as affective as pulling the terminal. i mean, if the fuse to the ECU is pulled, it should hold any power to the ECU anyways...right??
don't want to pull terminal now b/c working on stereo/equalizer configurations.
Old Aug 16, 2003 | 05:15 PM
Dave-ROR
Guest
Posts: n/a
you pull the radio backup fuse.
Old Aug 16, 2003 | 05:46 PM
typeruz's Avatar
typeruz
GOOD ONE!!!
Old Aug 16, 2003 | 09:26 PM
Dave-ROR
Guest
Posts: n/a
GOOD ONE!!!
uhmm it wasn't a joke. You really do pull the radio backup fuse. Sorry, but that is the answer.
People pull this fuse because it resets the ecu while leaving power to other things, like the stock head unit. Therefore, re-entry of the code is not required.
Depending on how you wired up your stereo components, this method may or may not cut power to your parts but it's not my fault if it does.
Old Aug 17, 2003 | 07:52 AM
typeruz's Avatar
typeruz
oh, thanks! thought that was a joke.
