Valve Calibration
Old Aug 4, 2003 | 06:10 PM
tipoR's Avatar
tipoR
I recently bought my JUN type 3 cams but i cant get the right calibration on the valves.
Someone that knows please tell me....
I know that for stock DOHC is 25 in the intake and 20 in the exhaust,
but i cant get it right.
PLEASE HELP>>>
Old Aug 4, 2003 | 09:06 PM
Jan Niemi's Avatar
Jan Niemi
I hate to be a nitpick but you can't calibrate valves, you can adjust valve lash, you may have to experiment with it. If you are having trouble, you should attach a vacuum gauge to the intake manifold, and monitor vacuum levels at idle and try to achieve the best idle vacuum. A stock car will idle at about 21" of vacuum, so use that as a reference. You may have to increase the valve lash to get the right idle vacuum which will mean a noisier valve train. Good luck to you man.
