increase torque...
Old Jun 16, 2003 | 06:24 PM
mayhem's Avatar
mayhem
What is a safe way to increase torque besides forced induction?I'm completely stock
Old Jun 16, 2003 | 06:30 PM
sscguy's Avatar
sscguy
Bore your engine out to 2.0 liters or...don't drive a Honda... heh heh. Realistically, i/h/e, cams but you'll need to tune them properly, and if you go that far, maybe Hondata or VAFC. Someone else, I don't know if P&P headwork will increase torque, I thought that was more for high-end hp.
Old Jun 16, 2003 | 06:32 PM
Dave-ROR
Guest
Posts: n/a
most mods will increased tq. You can't increase HP without an increase in torque (at x rpm).
How much torque do you want? top end? low end? midrange? across the board? etc?
Old Jun 17, 2003 | 04:48 AM
George Knighton
Guest
Posts: n/a
What is it that you're trying to accomplish? What would you like the car to do that it's not doing now?
If you want a little, cheap (free) boost, just make sure your initial spark advance is set to maximum within spec (18 degrees). This will give you a slight but definitely perceivable boost across the power band.
That's the only free thing I can think of, but if you tell us more about what activities you're participating in that you want this torque, that would help us advise you.
Old Jun 18, 2003 | 07:04 AM
typeruz's Avatar
typeruz
how can i set the initial spark advance???
do i need any special tools?
thanks!
Old Jun 18, 2003 | 08:23 AM
Jan Niemi's Avatar
Jan Niemi
Yeah, that's tough without stroking the motor, or boost. Torque is all about leverage, and with a short stroke like our Hondas have it's tough to do, that's why we make it up in the upper end with crazy revs. If you really want torque drop in a V8.
Old Jun 19, 2003 | 03:58 PM
mayhem's Avatar
mayhem
Basically, i just want to get out of the hole faster,im not doing any track or autox atm.Low end is what im looking for
Old Jun 19, 2003 | 04:38 PM
Zodiac R279's Avatar
Zodiac R279
Well there are some things you can do to to add a little torque. Honda used a stiffer valve train and lighter valves on the intake side in their 98 spec R's Vs the 96 spec.There was an increase of .5Kgm (about 4 foot pounds) in the 98 Spec over the 96 Spec. Not only that the 98 SPec was 19kgm(137 ft-lbs)@6200 while the 96 spec was 18.5kgm(133ft-lbs)@7500
So this along with the ECu added a bit more Torque and moved it lower.
No if you want to keep the torque on the low end you might want to kgo with a 4-2-1 Vs 4-1. Go with an exhaust no bigger than 2.25" Mugen Twin Loop is suppoesed to be goo to maintain torque as well, but I don't know that First hand
Old Jun 20, 2003 | 06:48 AM
JiggyKooAndy's Avatar
JiggyKooAndy
your never gonna even compare to an 8 cyl out of the hole and what not...hondas are known for their top end...hence vtec. What do u need to get out of the hole better for? If it's for racing...you should be launching at 5000-5500 anyway...so that's right before peak torque and right before vtec engages.
Old Jun 20, 2003 | 11:03 AM
CanadianR's Avatar
CanadianR
No offense meant, but if you want a car with low end tourque you shouldn't have gotten a Type R, or a honda for that matter. But yeah, any bolt on will increase tourque in order to increase hp.
