Engine pull to Jdm front end conversion...
Old Jun 12, 2003 | 05:52 PM
ITR 97-143's Avatar
ITR 97-143
Welcome i am writing for some of the people out there that want to work on there type r but need a guilde or know how to and just need some pointers .
To Start off
Removal of the front Bumper For the jdm convertion (SKip to post 2 if you are droping your motor out.)
1.Remove all the screws from the bumper skin ..
there is 8 on the top of the core witch holds down the front bumper cover brace bar , one on each side that holds it to each fender. two on each side that holds on the front lip to the bumper and fender liner. and one on each side that holds the front bumper to the fender liners on the bottom and 2 10mm bolts that hold the bumper skin to the lower core support.
and there is 2 10mm bolts that are on the top on the core support that you will need to remove they are on each side that hold down a black brace that is hooked to the front bumper .
once you have removed all the Screws and bolts then you can start removing the front bumper from the car by grabing the bumper on the right or left side by the back and pulling down a lil bit you will notice that it will come out of is place, most of the time the bolts for the headlights will catch the top of the bumper and make it not want to come off all you need to do is grab the lip and pull up and it will come off..
once you have the bumper skin off just twist out the marker light bulbs and take you bumper and set it in a nice place so it doesnt get Scrached up.....
Old Jun 13, 2003 | 01:29 AM
ITR 97-143's Avatar
ITR 97-143
now that you have your front Bumper off ...
Engine Removal.....
1. Set your E-brake
2. jack up your car and set it on jack stands
3. Drain your coolant and tranny Fluid. (oil also if taking apart the motor or you just need a oil change)
