strange wistling noise
I can only describe it as a constant chirping noise (subtle) that appears >2000 rpm. It comes from behind the valve cover near the injector rail(not injector chatter). It sounds like a vaccum leak...but I cannot find one.
any advice appreciated thanks in advance
Dev
Dev
Grasping at straws here....do you have a Comptech Foam Filter? If so, that may be the source. I have a turbo like whistle from my car at certain throttle positions because of the comptech filter.
Dev
Dev
RPM, which concerns me, The whistle sound like it is coming from deeper than the throttle body.
I wouldnt be so crazy about it if I had heard it all along, seems like it had appeared w/in the last 500mi.
Im going to go out on a limb here and assume the worst.
I know we have loads and loads of intellegence on this board..Ive seen the pics from the Expo :lol:
So the whistle has a Hz property, It tends to run in cycles. It starts quiet, quiet >= to 1700 rpm and begins to cycle at about 2000 on (a bit louder) My concern is that there could be a bearing that is about to peace-out on me. Has anybody had a bearing commit suicide..maybe you can describe the sounds you heard prior.
One last question, I know honda (type-r in particular) is known for tappy valves, but could the whistling be due to high cycle pinging (made up that term)
Thanks
Dev
Thanks
Dev
My stock intake made a faint whistle sound like you are describing, and does the same, only louder with my current comptech icebox. It only really makes noise on low-mid throttle positions from between 2-4k rpm.
