TO4E Turbo
Old May 19, 2003 | 11:29 AM
Worangejuice32's Avatar
Worangejuice32
Yo guys, I'm looking at a 1995 GS-R with TO4E turbo on it. He's sellin' it for $9000 and it's got 75k on it.
Any way my real question is that that is all that's on their, he says all the lines are hooked up but he has nothing else on it. (blow-off valve, intercooler, and all that other stuff I'm just learning about). What other parts will I need to run this turbo. Need a rough estimate on a good setup.
Good deal??
Let me know guys.
Thanks!!
Old May 19, 2003 | 11:32 AM
Worangejuice32
http://www.autotrader.com/findacar/v...lor=&cardist=3
Old May 19, 2003 | 12:48 PM
ITR41's Avatar
ITR41
if you want the car to last on stock internals I will say atleast 2 grand more. you will need:
Injectors, AFC, Fuel pump, BOV, FMIC and all piping, head gasket, block gaurd, clutch, Flywheel, etc.
Old May 20, 2003 | 02:33 AM
Jan Niemi's Avatar
Jan Niemi
That's a nice turbo (the same one I run on mine)
Just make sure that the car hasn't been run with the turbo on it without
being connected to the throttle body, this would cause severe overspin and the turbo would most probably be damaged.
Old May 23, 2003 | 01:43 PM
Worangejuice32
He said that the turbo is sitting on the exhaust manifold but that there is a cai, so the turbo is not hooked up or running. Yeah it still needs the piping and all that. It sounds like a decent deal to me. Any info would be appreciated.
Thanks!! :shock:
Old May 26, 2003 | 01:54 PM
Jan Niemi's Avatar
Jan Niemi
If he is driving the car with the turbo mounted on the manifold, even with a cai, the turbo is still spinning (overspinning) because there is nothing there to give it backpressure. If this is the case, inspect that turbo with a keen eye, because it's probably damaged.
Old May 27, 2003 | 10:45 AM
Worangejuice32
What should I look for on the turbo to tell if it's in good or bad condition. He says that fe started the project but needs money and just didn't finish. Sounds ok to me. But I will defenitely have an inspection.
Thanks
Old May 27, 2003 | 01:42 PM
Jan Niemi's Avatar
Jan Niemi
You can check for shaft-play, but really you won't know if the bearings leak until you start boosting.
Old May 27, 2003 | 02:42 PM
Reid's Avatar
Reid
Stay away from the car.
It's not worth your trouble to buy someone else's problem.
If you want a turbo GSR, buy a stock GSR and turbo it.
That is the only way to ensure things are done properly.
Old May 28, 2003 | 08:04 AM
Worangejuice32
Is this from experience? Would the rest of you guys agree? Not that I don't believe you but just want to be sure.Hmmmm
