ball joints...
need some help, this chiltons is useless.
is the link for where the steering connects to the hub/suspension/wheel on the front a ball joint? If so, when i try to remove the bolt the ball joint just spins and spins. At first i thought it was broke, but then i realized its a ball joint. How do you get a nut off of a ball joint if the nut is frozen?
Originally posted by qtiger
Did you remove the pin?
upper ball joints took me 3hours/ea to free up, (chiltons told me i couldnt?)
anyway, the bottom steering linkage, i just wanted to make sure it was supposed to spin, and that the bolt wasn't loose or broken.
Originally posted by ManTiS
Valvoline penetrating lubricant(hehe).
ANYways. if i need to, i dont really need it off, i just didnt know if it was normal or not. when it comes time ill just take a dremel to it.
i should call my self "fujiwara macGuyver"
Why you roll your eyes? Valvoline claims that it is better than wd40. A new castle nut costs $3-4
