Tire size for stock, daily driver rims?
Well, my tires are bald on my daily drivers =\ I did a search and Trey recommended getting tires in 205/50/15 size. I've decided to go with the Yokohama AVS ES100's but why not the stock tire size (195/55/15) or a lower profile version (195/50/15)? Any opinions on recommended size?
Bear in mind that I have a seperate set of rims for racing (wrapped w/ 205/50/15 Falken Azenis) and that I live in DFW, TX, where the most inclement weather we get is rain every once in awhile.
Guest
Posts: n/a
Matter of taste, preference and price.
Some people would say there's no point in going w/a 195-55-15 when the 205-50-15 is more rubber on the road, and the same price or cheaper.
Some people would say there's no point in going w/a 195-50-15 because it's a lower load rating and (perhaps, some would say) not quite as safe and up to high performance driving.
All personal preference.
Personally, I'd go with 205-50-15.
I have a set of Potenza RE730's, in 205-55-15 for my everyday driving. They're great for daily use, handle rain fairly well, and are a pretty good performance tire. I got the larger size only because I felt the stock R looked a little under-tired, and the slightly larger size seems to help the look a bit, tho I honestly don't know how much a visual difference they really do make.
Nuts, you people are making me spend more money on those wider tires :P I'll take you guys' suggestion and get the 205's unless money gets a little tighter for me, in which case i'll just be sticking with stock 195/55/15 tires size.
Guest
Posts: n/a
Originally Posted by kabob
Nuts, you people are making me spend more money on those wider tires :P I'll take you guys' suggestion and get the 205's....
Are you thinking of Azenis, or something else?
Don't know about that controversy but the stock RE010s are too expensive for a daily drive tire, anyways so I was thinking more along the lines of something with better performance to dollar value like the Yokohama AVS ES100
I believe the controversy with the 205/50-15 RE010s is that the are built as front tires for the NSX, and have a seperate bias depending on L/R sides.
Just checked TireRack, the Yoko ES100 is 195/55-15 is only $57 ea vs the RE010 @ $123 ea. I'd say the Yoko is a lot more bang for the buck!
205/50-15 in ES100 is $72 for comparison.
