clutch noise
Old May 14, 2003 | 09:22 AM
type_sml's Avatar
type_sml
i have a squeak in my clutch when i release it slowly. i need to know if anyone has had a similar problem at all. I blead the clutch a few times to see if there was any air in the line at all, but that didn't work. I cleaned off the ball on my slave cyliner and re-greased it, which seemed to work, but the noise came back after only 2 days. Does anyone know what could be wrong? Any help would be great. Thanks.
2001 ITR 342
Old May 14, 2003 | 02:54 PM
Jan Niemi's Avatar
Jan Niemi
Look under your dash, above your clutch pedal to see if the clutch master is leaking, sounds like the clutch master to me.
Old May 14, 2003 | 05:28 PM
type_sml's Avatar
type_sml
will do, thank you. I will check it out for sure.
