clutch noise
Old May 14, 2003 | 07:16 AM
type_sml's Avatar
type_sml
I have a certain squeaking noise in my clutch after i drive for about a half hour. I have blead the clutch a few times to see if it goes away, and it doesn't. I took off my slave cylinder and cleaned up the ball, and re-greased it, which made the noise go away for a bit, but came back after about 2 days. I am kinda stuck now. Does anyone know how i can get rid of this noise? It is more noticable when i release the clutch slowly.
Thanks.
Old May 14, 2003 | 07:50 AM
Trey
Guest
Posts: n/a
My guess would be the spring in the clitch pedal itself. Had this on my old GSR.
Old May 14, 2003 | 09:17 AM
type_sml's Avatar
type_sml
i am just not sure why the noise would have went away for a couple days when i cleaned off the ball on my slave cylinder. i will be dropping the tranny next week and adjusting my flywheel, so i might just end up cleaning everything out inside. I will check the spring though. Thanks a lot.
Old May 14, 2003 | 10:15 AM
Reid's Avatar
Reid
I had never had a problem with clutch pedal squeaking until I read about it online.
Then one day it just went away and never came back.
