How much whp?
Old May 8, 2003 | 11:11 PM
v t e c 2 3's Avatar
v t e c 2 3
how much whp does the itr make bone stock?? and how much torque?
Old May 9, 2003 | 04:51 AM
jetydosa's Avatar
jetydosa
Ive seen everything from like 156ish/112ish to 163ish/118ish.
There used to be a page, Integra Dyno Center that had all sorts of dynos of Integras including Rs, but it has moved and the new page just seems to pop up ads everywhere. There are some stock ITR dynos on http://www.bseries.net/html/dyno/NA.php as well to check out.
Old May 9, 2003 | 05:31 AM
George Knighton
Guest
Posts: n/a
My car was 158 bone stock, on a Dynojet.
Victor's '97 was 162 bone stock, on the same dyno on the same day.
Old May 9, 2003 | 08:25 AM
Trey
Guest
Posts: n/a
I had one dyno 168/121 and one Dyno 160/116 on the same dyno. they were 2000 and 1998 models respectively.
Old May 10, 2003 | 12:32 AM
Aj's Avatar
Aj
Mine dynoed at 165.1whp with 121.2 ft/lbs. That was on the Dyno Jet at Street Rods and Classics, who turned out to be mad shady, for any one thinking of going there, beware!!!
Later,
Aj
Old May 10, 2003 | 07:15 AM
descartesfool's Avatar
descartesfool
For a few dyno curves on Integras, you can check out the two following sites:
www.dynocenter.com/home.html
and the 1.8 Litre section of the dyno charts section at
www.importreview.com/main.html
However if you aspire to truly aspirate some serious quantities of air for some scary hp numbers, check out this site. I think they make 168 hp at idle!
www.z06vette.com/perfdata.php
Just put two 4 cylinder motors in.
