cam
Old Apr 27, 2003 | 02:12 PM
ITR99's Avatar
ITR99
which is the best cam and what does it exactly improve?
Old Apr 27, 2003 | 04:39 PM
George Knighton
Guest
Posts: n/a
You'd better tell us what you're trying to accomplish, first.
Old Apr 27, 2003 | 04:43 PM
ITR99's Avatar
ITR99
I just want to have more low end torque and overall higher hp
Old Apr 27, 2003 | 04:55 PM
George Knighton
Guest
Posts: n/a
Well, to be honest, you can get that without buying cams at all.
Here's an example of what you can do without cams:
Old Apr 27, 2003 | 05:31 PM
Aj's Avatar
Aj
yeah, not to mention, I don't think you entirely undestand what must go into a car to get a set of cams to function efficiently, and effectively.
To give you a quick understanding, in parts alone, not including any sort of management or peripherals needed. You'll spend between 1500 to 2000 on a nice setup. And, as I said, that's not including ECU, injectors, fuel pump, fuel pressure regulator, and a whole slew of other parts.
At the bare minimum, you'll need to invest in a set of Springs, Ti retainers, and cam gears. Then add the cost of the cams, anywhere between 650-1100 bucks alone.
Also, another problem you'll run into using cams with higher lift and longer durration, is that you'll be needing higher compression. Usually rule of thumb, more lift = more compression needed. For example running a set of Toda Spec-C cams on stock compression is completely out of the question. Yes, they would work, but not as they were designed, nor at all efficiently. There is much horsepower to be gained from cams, but needs to be done as a process, and not just slap them in and pray...
Any way, as I said, do some more research before you just start buying parts, otherwise, I'll garauntee you'll be sorry....Goerge is definitely right, do all the bolt ons first, and once you have gotten a good working knowledge of your car, and what components are needed for what, then re-assess your need for cams.
Later,
Aj
Old Apr 27, 2003 | 06:09 PM
RedKroovy's Avatar
RedKroovy
George what kind of bolt ons are you running
Old Apr 29, 2003 | 08:54 PM
George Knighton
Guest
Posts: n/a
Complete SMS system, header on back, with cat.
Intakes: A custom SMS intake for the test, but I switched back to the Icebox to reduce noise.
Hondata, fuel pressure regulator.
