Cleaning the v-tec
Old Mar 12, 2003 | 07:55 PM
SanjayR's Avatar
SanjayR
Isnt there someway to clean the V-tec filter or something like that. One of my friends was telling me how it made a diffrence after he cleaned his. Does anyone know anything about this. If so how do you go about cleaning it.
Thanks
Old Mar 13, 2003 | 04:24 AM
Trey
Guest
Posts: n/a
Never heard of a VTEC filter. There is a VTEC solenoid but I haven't heard of cleaning it either.
Trey
Old Mar 13, 2003 | 08:24 AM
Jan Niemi's Avatar
Jan Niemi
Ask your friend, and when you're at it, ask him to show you where the "vtec filter" is.
Old Mar 13, 2003 | 10:04 AM
SanjayR's Avatar
SanjayR
If your looking down at your valve cover its on the left in between the distributor and valve cover...its that little round thing its like an inch high....and i think he might have said soleniod. I'll ask him when i see him again. Hemight be full of shit i dunno.
Old Mar 13, 2003 | 11:11 AM
Erik B's Avatar
Erik B
I think he might have been f^&@%#^ with ya mang.......:lol:
Old Mar 13, 2003 | 04:04 PM
kabob's Avatar
kabob
That's the VTEC solenoid... and no, you don't clean it other than when you clean the rest of your engine bay. A filter? Filter what?
Old Mar 13, 2003 | 04:54 PM
Sick TR's Avatar
Sick TR
his probably cofusing the intake with the vtec.
Old Mar 13, 2003 | 09:59 PM
Aj's Avatar
Aj
Well, did he also tell you to maintain your muffler bearing, or perhaps your water filter.....
there is no such thing as a Vtec filter, and there is no purpose on cleaning your solenoid, unless you really want to spend a couple bucks on a new gasket.....
Slap your buddy, and tell him to stop screwing with you, or if he really thinks it made a difference, tell him to get real...
Later,
Aj
Old Mar 17, 2003 | 04:14 PM
Kali ItR's Avatar
Kali ItR
there is a filter!!!! its called the spool valve.. take off the vtec solonoid and its like a gasket/filter looks like a fine net. clean with brakeclean. the filter filters out any debris. if the filter clogs the spool valve will drop oil press to the rocker arms and vtec will not turn on or turn on on some cylinders and not all. also the filter keeps out debris so the timing piston(the little rod that connects all the rockers to the deep cam lobe) wont stick. if its not clean it would throw a check engine light. (p1259 dtc) i know because im a honda tech. and had a shitty experince with that on an accord.
Old Mar 17, 2003 | 10:30 PM
Aj's Avatar
Aj
I wouldn't exactly call a mesh screen a filter, but calling it what you will, I've never had to clean one, in all the motors I've built, had built, and seen built.....either way, it's not necesary, and it's one of those things that either works or doesn't work...
Later,
Aj
