The best way to set tire pressure IMHO is to use a pyrrometer(Measure surface temps) do a few hard acceleration runs and measure the temp across the tire before and after each run. You want even temp across the tire. You can also do a trial and error thng and see what pressure hooked up best, it will vary with different weight vehicles
Ah, I see... cause if it's hotter around the edges it's too low and if it's hotter in the center it's too much. h:
Cool, where would I get one of these devices? Price?
from the research i have done, most people recommend 18psi-22psi, that what has worked best for the majority. I too just barely bought some BFG DR's. I just got them mounted today on my extra set of ITR wheels, i'll have to test them out soon :-)
and i kno before u got them u spun like crazy with the power u r packing, so if u like them, i have to get me a set, thanks.
just have to do my research on what brand to get.
