FS or WTT: 1990 Accord LX w/ h22a
want to sell for $3200 or trade for a 92+ civic hatch or an 88-91 CRX...manual only.....must run good and the less mods the better
NORTH ALABAMA AREA
1990 Accord LX 4 door
VIN# JHMCB7656LC055914
clean title, never wrecked, I'm the third owner
ran a 14.5 @ 96mph in fall of '03 on street tires
140K miles on chassis, 50K on the rest, less than 1K on tires
ENGINE
1995 JDM H22A with around 50K miles....swapped in spring of '03
polished short ram intake
bypassed the TB coolant lines
JDM header
2.5" custom exhaust/no cat/turbo muffler.....not too loud
removed the P/S pump but still have it and it's still good
has cold A/C, very hot heater
H23A1 manual tensioner conversion--new parts
new timing belt, new water pump, recently adjusted valves
all tune up stuff is new, new fuel filter, perfect mechanical shape
KMC EGR block off plate
TRANNY
JDM H22A tranny w/ OEM LSD using synchromesh
Centerforce Stage II clutch
Clutchmasters Lightweight flywheel
new slave cylinder/clutch master cylinder/reservoir
OTHER
chipped p28 ecu--NO ks, speed or rev limiter, 4800 vtec x-over
4bidden short shifter--no console interference...3 positions
1995 Accord EX 7 spoke rims w/ new yokohoma 195/55/15's
Alpine cd player/pioneer 3-way factory sized speakers front/rear
wired for amp already too
255lph walbro hi flow fuel pump
4 hi beam headlight conversion with polarg bulbs
blacked out OEM headlights with no leaks
blacked out OEM corners and bumpers
top part of tails are smoked but backup light is still clear
smoked and functional side markers
mechanically the car is in great shape......well maintained in every way......inside is in great shape...no tears or holes in seats, no cracks in dash and in VERY good shape.....floor mats are gone though.....i tried to clean them and successfully KILLED them
has a few dings/dents that can be fixed....hood opens/closes perfectly but is dented on the front.....needs a CF hood to "pretty it up"....ready to make a trip wherever it needs to go though....super reliable, rides very good and stock suspension is still very good
NORTH ALABAMA AREA
ENGINE
JDM header
TRANNY
OTHER
Originally Posted by ZiviCase10287
bump for a good price.. but i got a question, did you use your stock motor mounts for the H22 swap? one of my magazines says in the 4th gens you can use your stock motor mounts... is that true?
yep.....just have to tap and drill a couple of holes for the one mount
Widebody NSX
Nov 7, 2002 07:18 PM
