I have more problems
Alright here is the deal...when i am driving anywhere between 35mph+ i start to here this wierd sound. The sound is like a metal rasping or like taking to coins and rubbing together. its not real loud but its real distinct....i thought maby rotors for a second. when i slow down it will stop, then like 5 minutes later when driving i will here it and then it will stop. Any clues on what it might be?
Heat shield? :thinking:
One of your calipers or rear brake cylinders could be sticking... it's hard to diagnose a problem when it is described rather than hearing it first hand.... :happysad:
i thought heat shield too....because the sound you can only hear with windows up. my tranny has been acting up real bad and i thought something there also....i will just take it to HONDACURATE and have my friend there look at it.
:rofl:
couldn't... I'm a mod.
Honestly, it's hard to tell what the problem could be without hearing it first-hand.
Pretty much anything can rattle. You could just go around checking to see if bolts are loose.... I do that from time to time. :happysad:
h: :eek3:
