bleeding the clutch
Old Jan 21, 2004 | 07:40 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
Default bleeding the clutch
Anybody have any hints on doing this?? If so it will be great.
Old Jan 21, 2004 | 07:49 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Do you have a cable or hydraulic tranny?
Old Jan 21, 2004 | 07:55 PM
vtecadil's Avatar
vtecadil
most likely hydraulic cuase i dont think u bleed cable clutches plus its got a 92 or newer engine and tranny. but there is a little valve on ur slave cylinder well thats what i call the thing, but u turn that and then have someone pump ur clutch 5 times and then its suppose to bleed it, im just puttin up the sketchy details, i think im leavin something out but that is what i was told, if anyone wants to correct me or add on please do.
Old Jan 21, 2004 | 07:57 PM
Nelson's Avatar
Nelson
Administrator
Yes, it's very similar to the how you would bleed your brakes...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jan 21, 2004 | 08:24 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
look at slave cylinder on the end. there is a bleeding nipples. use an 8 mm closed ended wrench. turn towards the front of the car to loosen, and turn towards the motor to tighten.
top off clutch master cylinder
make sure system is closed.
have friend pump 3 times and hold on the 3rd pump.
loosen the bleeding nipple.
let air and fluid burble out, close tighten the bleeding nipple.
check clutch master cylinder make sure you aren't low on fluid.
have friend start pumping again.
repeat till all you see is fluid coming out, no bubbles at all.
pump 5 times or 3 times. i usually start off with 3 and then up it to 5. don't really matter.
Project EVA - The Track Package
Project EVA
Old Jan 21, 2004 | 08:28 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:werd:
It's simple, but you must have a friend to do it.
Old Jan 21, 2004 | 10:13 PM
honura's Avatar
honura
Seni
Unless your a mad scientist who can make something to pump the pedal from the outside ! :fawk:
Old Jan 21, 2004 | 11:05 PM
Hondaman's Avatar
Hondaman
Black Pearl
I have a vacuum pump for such jobs. Works very well when you have no friends, like me.
Old Jan 22, 2004 | 11:02 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Originally posted by westcoaststyle
:werd:
i had to do it all by my lonesome when I replaced my clutch mc
I ran a hose from the bleed nipple to a bottle of water where I could see from the drivers seat and pumped while watching for bubbles in the bottle of water.
Old Jan 22, 2004 | 11:27 AM
Civic2Scooby's Avatar
Civic2Scooby
I had to do it by myself too...pumped it...then wedged a 2x4 between the seat and the clutch....then ran around loostened...etc etc...repeat process
