VERY sluggish GSR :(
As you might have seen, I got a B18c1 installed in my coupe over the weekend. Its a stock B, with only intake/exhaust. I was originally going to get a B18c5, so I got a chipped P28 ecu with 5 chips: Jun, Mugen, Skunk2, Stock, Custom N/A.
I'm wondering what ECU would be best to run on a 95 GSR?
Can I use the chipped P28 with a ITR chip? Should I just use my stock P28? Would a 95 GSR ECU work best?
What chip would I need to run Hondata? I'm planning on getting that next month, but need to know what to use for the time being.
Thanks!
Thanks!
Originally posted by Spike
Ok...should I keep my stock P28 for use with Hondata?
And just get a P72 for now. Will a P72 just be plug-in-play for my wiring harness?
:edit: PM Phiz if you need one
I was wondering what the title and the topic had to do with each other. Good luck getting it fixed.
i'm guessing the sluggishness is because your secondaries aren't opening up.
oh how do you know you blew a head gasket/
how's the compression on the cylinders/
