My sedan broke
Had to walk three miles in the cold ass wind
Pretty sure its the fuel pump how much is a new one? Is it difficult to install?
:edit: it was more like 1 mile actually
h:
Pretty sure its the fuel pump how much is a new one? Is it difficult to install?:edit: it was more like 1 mile actually
h:
I know the aftermarked 255LPH ones are about $100, but that would be too much for a stock motor.
I'm not sure how much a new one is. It's a really easy install. You have to remove the back seat... then it's really stright forward.
Originally posted by white_n_slow
could be the under-dash fuel relay too. You should be able to hear wether or not your fuel pump is turning on when you trun the key.
What should i listen for? I mean what will it sound like? This is probably a dumb question oh well.
normally when you turn the key to the 'on' position, but don't turn it over, you can hear a faint kinda humming sound. If you hear that still, your fuel pump is probably ok. If you hear nothing, the pump probably kicked the bucket.
