I need a little bit of help with my H23A engine swap...
I am in the process of swapping a 2000 Honda Accord Euro R H23A DOHC VTEC engine into my 1992 Honda Civic CX Hatchback. I've included my "list of things that I need" below, and I was just wondering if I may have forgotten something...
Moroso axels
Shift Linkage
Skunk2 Camber Kit
AEM V2 Cold Air Intake
HASport Motor Mounts
Koni Shocks and Springs
Ceramic/Kevlar Brake Pads
DC Sports Ceramic Headers
JIC 505ST Exhaust System
Skunk2 Short Throw Shifter
Brembo Drilled and Slotted Rotors
GSR Rear Disc Brake Conversion
Fluidyne Aluminum Radiator
16” Yokohama Parada Spec-2’s
Quaife Limited Slip Differential
Momo Black Leather Shift Boot
16” Flat Black Rota Slipstream’s
Autometer Carbon Fiber Tachometer
Momo Real Carbon Fiber Shift Knob
Hondata OBD2-OBD1 Conversion Harness
Energy Suspension Polyurethane Shifter Bushings
Engine Maintenance Parts (clutch, belts, etc.)
Random Technologies High Flow Catalytic Converter
Also, does anybody know if this particular transmission has ATTS or if the engine has an immobilizer? Does anybody have any estimates of what my car might run (the car is also stripped down except for the front two seats) in the 1/4 mile?
THANKS YOU FOR YOUR HELP!
-Dan
Moroso axels
Shift Linkage
Skunk2 Camber Kit
-Dan
to be honest a lot of the stuff you listed seems like extra which is fine also.
just make sure you have everything you need for the power steering and ac to bolt back up, if it's even poosible. i can't remember but you may not be able to keep ps, or ac with that h series swap.... could be wrong though.
