b16a2, H22a blow out $800
Old Jan 12, 2004 | 08:07 AM
osakamotors's Avatar
osakamotors
HAN Approved Vendor
Default b16a2, H22a blow out $800
Super Sale on b16a2 long block $800 only
http://www.osakajdmmotors.com/longblocks/index.html
Also, H22a long block in special with unbeatable price: $800!!!!
HUPPY UP, offer ends soon.
Just make your call right away: 1-800-270-5712
Old Jan 12, 2004 | 05:54 PM
osakamotors
HAN Approved Vendor
Hey guys,
the longblock comes with the following parts
engine
distributor
intake
manifold
alternator
accompressor
pspump
all required sensors and cables
uncut engine harness
plus the auto ecu which comes with the longblock
and you can easily put a manuelle chip inside which is going to cost you maximum $150US and the ecu is going to manuelle
thanks
Old Jan 12, 2004 | 07:14 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
How much you charge for heads?
Old Jan 14, 2004 | 07:58 AM
osakamotors
HAN Approved Vendor
Hi there,
we dont sell jus the head, all we got in stock
is the longblocks, which is the complete engine only
but no tranny, the longblock comes with all the components
around the engine
thanks
Old Jan 14, 2004 | 08:16 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
Do you sell just the transmitions as well? If so how much does an ITR tranny go for?
Old Jan 14, 2004 | 04:20 PM
Lark03's Avatar
Lark03
...will a H22A fit a 92 LS??!?!! or would that be one hard swap?
Old Jan 16, 2004 | 06:47 AM
osakamotors
HAN Approved Vendor
Hi there,
we dont carry the ITR tranny for now,
since they are becoming very hard to find them in
japan nowadays, but we do carry the manuelle 5sp tranny
for the JDM H22A OBD1 which goes for $500
the tranny comes with 55000 miles max on it
thanks
Old Jan 16, 2004 | 06:54 AM
osakamotors
HAN Approved Vendor
Hi there,
its not that hard to do the H22 into your 92LS,
but you would need the mountkit, custom axels, the
H22 shifter and the shifter housing, and the swap
this is all what you would need to make the swap complete,
but we have another good easy swap, its the
JDM B16A2 with cable tranny, the motor comes with 170HP
and its out of integra 92-93 model only in japan, the motor
is OBD1 with the OBD0 tranny, this is the easiest swap for you
you dont need the axels, shifting linkage, and the mounts '
because you can use your stock ones, they are all the same
all you need is the motor tranny uncut harness and ecu
and this is all for $1200, the motor is very clean and comes
with very low miles, this is the best swap for your 92LS
thanks
