What is this fuse for?
I was looking through the fuse box under the driver's side (96 GS-R btw) and saw that some fuses were missing or not meant to be there so I want to check with you guys, since I bought the car used and it did not come with an owner's manual. There are two empty slots for 10A running light and 7.5A running light relay. Correct me if I'm wrong but I'm pretty sure those are for maybe Canadian models?. There is this other fuse that has a black chip thingy stuck in it and the name of it is "15A ACG(IG)" and does not look like a fuse chip to me. I cannot take it with the fuse puller and I didn't want to try using anything else in case it wasn't meant to be taken out. Any info on this?
