Heater blows cold air
Old Jan 8, 2004 | 10:35 PM
yojasonyo's Avatar
yojasonyo
Default Heater blows cold air
As the subjecct says...my heater blows cold cold air...i let it sit and warm up for like 20 minutes, and it does the same thing. freezing cold air, =( Anybody know what this could be?
Thanks
-jason
Old Jan 8, 2004 | 11:48 PM
nevets's Avatar
nevets
WAAAGH!!
my best guess would be the heater valve.
Old Jan 9, 2004 | 12:03 AM
Hoist's Avatar
Hoist
My name is Mud
maybe you are somewhat confused and turning your air conditioner on? Instead of your heater? Hey man it could happen, I get confused too
Old Jan 9, 2004 | 07:45 AM
JimBlake's Avatar
JimBlake
Maybe the cable that connects the control to the heater valve is broken. If you're lucky it's just disconnected.
Old Jan 9, 2004 | 08:49 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
This could be...to check the valve for your heater is below the glove box to the left. Have someone slide the lever on the HVAC controls from hot to cold to see if it moves.
Old Jan 9, 2004 | 09:08 AM
LT's Avatar
LT
The deer had to die!
what's your coolant gauge indicating?
Old Jan 9, 2004 | 10:15 AM
Prince's Avatar
Prince
easist: top up fluid. especially coolant
Old Jan 9, 2004 | 12:02 PM
JimBlake's Avatar
JimBlake
Mine has 2 cables. First one goes from the control slider down to the bottom of the console, passenger side, near the floor. It pushes a lever that works an air damper. The other cable goes from there thru the firewall to the heater valve. The heater valve is on the heater hose, against the firewall, kinda under the fuel filter.
Have someone work the slider control, while you watch for the cable to move at both of those places.
Air bubbles in the heater core can make it blow cold. You gotta find out whether that's your problem, or the cable.
