Integra oem hub
Old Mar 18, 2014 | 11:07 AM
gingas's Avatar
gingas
Default Integra oem hub
I'm trying to find out does beck/arnley makes the oem acura hub & timken makes the oem wheel bearings. Reason why I'm asking is because I need a hub for my front driver side & a wheel bearing for front driver side also. I called Acura & they want $225 for another hub & $148 for the bearing.
I then called Autozone & they only sell the wheel bearing made by timken for $82. So would you guys buy the autozone wheel bearing & the om hub from acura & just get that pressed & be done. I didn't realize the hub would be so expensive or another thing I thought about but not sure. Hub from a junkyard?
thanks
lmk
Old Mar 19, 2014 | 08:55 AM
gingas's Avatar
gingas
does anyone have suggestions
