computer options
Old Jan 8, 2004 | 01:16 AM
sekongen's Avatar
sekongen
Default computer options
I own a 91 LS with a b-16. im running the stock computer with the stock harness ( v-tec is hooked up to a switch on my dash. ghetto I know). I hear from some to get the PR3 computer and the others to get a P28. I dont exactly know why a single cam computer is a popular choice but if it works, why not. If someone could shed some light on this situation it would be greatly appreciated. Thanks.
Old Jan 8, 2004 | 01:00 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
P28 ECUs can be chipped to run a DOHC VTEC motor. The problem is that Honda changed the style of their ECU plugs starting in '92 and that's when the P28 ECU was introduced. You would have to hack up your stock '91 harness to run a P28.
The PR3 is a better option. It came in Japanese-market Integra XSi and RSi models, as well as the Civic and CRX SiR. These cars were all equipped with the B16. When using the PR3 there are just a couple of wires you need to add and it plugs right in.
Old Jan 8, 2004 | 01:39 PM
sekongen's Avatar
sekongen
So running a P28 isn't worth the trouble. Right on. Thank you very much
