engine swap question
Old Jan 6, 2004 | 06:13 PM
sbacchus's Avatar
sbacchus
Default engine swap question
hey all,
i have a 94 civic EX with a dead engine, i'd like to get it running again as cheaply as possible. the factory engine is the D16Z6 and i know the D15B is considered a direct swap. are there any other engines that would be considered a direct swap? could i install a D16Y7 for instance? i know the ecu would have to be changed if i did that, anything else have to be changed? i'm not looking for performance here, just to get this car running cheaply again.
also if you have any sources for a good deal on any of these engines please let me know. thanks.
Old Jan 6, 2004 | 08:44 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
I'd just start calling local junk yards and see what you can find. Best cheap performance option is another D16Z6 from any '92-'95 EX coupe/sedan or si hatchback. If your looking for dirty cheap, you can probably use any '92-'95 DX/LX engine as well, as long as you use the non-VTEC ECU, everything should plug in. I'd avoid an VX or CX as they both use different oxygen sensors than you stock EX setup (just wiring differences but why bother). You should be able to find a clean engine for less than $250 I would think. I'm assuming that the tranny/clutch is still good and it's a manual (not sure what would change with an auto, I'd stick wtih the same engine if it was).
