Help! I have water all over inside the car!
Old Jan 5, 2004 | 09:24 PM
lilcoldcrush's Avatar
lilcoldcrush
Default Help! I have water all over inside the car!
I started noticing water in the interior part of the car. At first I thought nothing of it because it had rained so I just thought that the wetness from my shoes got it wet. But after a few weeks it was still wet and I took out my floormats from the front and back and they were soaking wet. I also checked my trunk and everything was wet there too and also in my back seats and in the floor in the front seats and backseats. I've checked under the car for some kind of crack and I've tried to look everywhere but I'm just not sure where the water is coming from. Has anyone ever had this problem?
Old Jan 5, 2004 | 09:47 PM
Daniel's Avatar
Daniel
Got a sunroof? You have four drain tubes that come off of each corner of the sunroof assembly. One of those may have come unclipped, allowing water to trickle down the inside of the car, residing under your carpet.
Old Jan 6, 2004 | 05:28 AM
kilpatty43's Avatar
kilpatty43
corvette chick at heart
:werd: happened to my teg
Old Jan 6, 2004 | 01:59 PM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
http://www.team-integra.net/sections...6&search=drain
try that link..
Old Jan 6, 2004 | 02:12 PM
lilcoldcrush
what did you end up doing when this happened to yours? did you take it to the mechanic?
Old Jan 6, 2004 | 02:13 PM
lilcoldcrush
thanks for the link, i'll give that a try
Old Jan 6, 2004 | 02:21 PM
lilcoldcrush
thanks for the info drumsy, i'll check the drain tubes
Old Jan 6, 2004 | 02:29 PM
kilpatty43's Avatar
kilpatty43
couldnt tell ya...when i went to indianapolis back in november..my bf at the time installed my short shifter and some speakers adn did a few other things...he noticed the leak and fixed it for me...
Old Jan 6, 2004 | 09:10 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
wow, im glad I live in a state that doesnt rain much for once
Old Jan 6, 2004 | 09:13 PM
LT's Avatar
LT
The deer had to die!
i had the same problem, but it was with my taillight gaskets leaking water in. so i just popped out the drain plug in the spare tire well and problem solved.
