ITR Rear Trunk Bar thing
Since the ITR didn't have the rear-strut bars, it came with the bar that bolts on to the rear panel inside the hatch by the tail-lights, wat is that bar called? Does it have any function?
Also, kinda on the same subject, Does anyone have a rear-strut bar that you can install without cuting the left plastic cover on teh integra? The reason I am asking about the trunk-bar thingy for the Type-R is because I dont want to cut anything out of my integra..
My friends integra, he had to cut the bottom part too because it hangs lower. Did you just cut the pop-out panel or did you have to do anything to the bottom peice? The GAB Strut bar below rides pretty high so If i get that i wont have to cut any peice of the bottom out.
Here's what i did when i was on ebay looking for a cheap strut bar i found this one. It had very narrow ends, so in theory i wouldnt have to cut out as much. But when i really looked a it there was no problem i didnt have to cut any of the bottom out.
Looking at your pic i dont think you should have a problem. I can send you closer pics later once i take them.
Originally posted by CiViC2nR86
If i get a chassis brace like the one on the ITR, would it just be bolt on?
