96-99 Temperature Control
Old Dec 10, 2003 | 07:12 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
Default 96-99 Temperature Control
Alright....i just replaced the whole center bezel/climate control. The slider wire for the temp. was still fine so I hooked it back up(i know this part is correct) and all seemed fine. Went to put the heat on at night and it stayed cool. I think the back end of the wire might have gotten unhooked when they yanked the dash out. Where the hell is the other end of this? I cant see it under the dash anywhere, or under the hood. Hopefully that's all it is.
Any insight is appreciated.
also, any better shop manuals than the haynes? Was good when i was learning the car, but the more in depth stuff i'm doing doesnt get covered very well.
Old Dec 10, 2003 | 11:16 AM
Outxider's Avatar
Outxider
X-Motoring
look under the dash by the foot wells towards the center console, the temp control cable is connected to the heater box and on that box, its sits on a latch, if it falls off the latch, u cant change the temp at all. so look for it, adjust it and put it bakk on the latch. basically, the latch holds the black temp cable, and then the middle metal cable moves the temp control.
Old Dec 10, 2003 | 11:28 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
thanks, thats exactly what i needed to know! i was looking in the wrong spot for the temp control....couldnt follow the black cable far enough.
Old Dec 10, 2003 | 03:13 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
yea,..and a WAY better shop manual than haynes is a HELMS manual
Old Dec 10, 2003 | 03:18 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
oh and the title of this thread should be 96-98 temperature control ,...99-00 had electronic controls ,...stay tuned because ill be doing a write up on how to convert a 96-98 climate control to a 99-00 climate control
Old Dec 11, 2003 | 06:24 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
ah yes, forgot it was the 99-00 that was diff.
Old Dec 12, 2003 | 01:04 AM
xivera's Avatar
xivera
insert witty remark here
It's been done... There's a DIY @ honda-tech.com.
Old Dec 12, 2003 | 01:27 AM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
yes i know its been done,..but ill do my own DIY for honda-acura.net
